VXD-7200 - mic cable prog. cable pinouts and software question
motorolauser
Adelaide, South Australia
Hi All,
After some research, i have found the cable I need is either CT-150, CT-151 or CT-154. Are there any pinouts available for the CT-154 cable that connects to the mic socket ?
Also what software should I be looking for ? I have read that i will need VSCE or Vertex Standard Clone Editor. Old posts say it was available from Vertex Standard for free but all old links are no longer working ?
Many Thanks in advance for all replies received.
motorolauser
After more research, i have found this radio to be almost identical to a Motorola XPR-4550. It was easier to find a rear port programming cable as the usb just connects straight to it, no interface required.
Found service manuals for XPR-4550, just needing to locate software.
n3obl
O AES-1024
PA
It is the same radio. Just different firmware and the front housing has a mic with rj-45 type connector instead of the GCAI on the motorola.
motorolauser
With different firmware in the Motorola version, the Moto software would not work on the Vertex ?
Now the Vertex Standard software downloads section now gone, is there any other source for the Clone Editor software ?
