vxd 7200 vs radio stuck in vox
Pdmarter
Hi folks Question for anyone. I was programming my VXD 7200 I placed in vox mode for a zello repeater set up.. the problem is the radio is stuck in transmit mode.. any way of resetting the radio by the front panel or reset the whole radio to default mode. what i did was set the vox mode but did not turn off the tones nor did i click rear mic connection. I need to somehow reset the radio or turn off the vox . Thanks
radiotweester
Oregon
Can you disable the setting in programming, hookup, send from the computer and then power on the radio to receive programming?
I'm thinking older way of Vertex programming and I've not played with the Motorola bastardized units.
