DylanMadigan
I was able to get the CWID to broadcast every 13 minutes with use, but i got a couple questions. I have looked around a little and found some documentation on using CE27 but not too much. I am using the Windows GUI Application.
If it has been quiet for a while and I key up, the CWID wants to go off immediately after I finish my transmission. It does add a little delay for the other unit to answer which depending on whats going on can be quite inconvenient. Is there any way to delay that when we key up for the first time in a while, it waits a couple minutes until broadcasting the ID?
I have multiple PLs on one frequency to separate things out. When the CWID is broadcast, it goes over the last active PL. Can I have it go out with no PL so my radios don't hear it?
If I can have the ID go out with no PL, could I also set it so that if it is going off and someone keys up, it switches to repeating that transmission, then when thats done it goes back to broadcasting the ID?
