Our system used to consist of only two sites and we would manually switch between the two. Now that we've added a 3rd site they have set the radios to "automatically" switch. I thought this would be ProScan but evidently not. Instead, the radios don't switch until they lose the control channel, then go to WA Scan, and then pick up the better site. However, sometimes they will go right back to the same one! There are certain areas of town that when you are in a building, the portables continually go into WA Scan and lock right back on to the same site, making a loud beep. Other times they may switch to another one for a minute and then right back to the old one. There is a timing issue on one of the sites so some radios may be on one while others are on a different one, so some radios are about a 1/2 second behind on the audio. It's extremely annoying, not to mention a hassle when you're trying to talk and the radio keeps going to another site.
The other problem is that the mobile radios will stay on one site even though voice communications are all but worthless. The radios used to show which site you were on but now the only way to know is by manually scanning through.
Supposedly ProScan could be enabled on our radios but it would cost several $$$ each, so they opted not to do it. The administration doesn't really see what the big deal is.
Are there any adjustment that can be made to the way WA Scan works so that these problems are less of an issue? It seems to me that the threshold for going to WA Scan needs to be decreased on the portables and increased on the mobiles.
