hmburgers
I'm going to pull the trigger for an exterior antenna--thinking of the Scantenna (ST2?) as I am receive only and 90% in the 470MHz band for my listening with the other 10% being 2-meter ham listening and a bit of 800MHz for the State PD.
I have to go wall mounted because I am not willing to go on my 12/12 pitch roof.
The house is a Cape style, no dormers, so my plan is to use a set of 4" or 6" wall mounts next to the second floor window under one of the gable ends--essentially the mounts will be placed where a decorative shutter normally is.
The top of the window is about 6' shy of the peak of the roof, so I think I would need a minimum of a 10' mast to get the top of the mast up near the peak. I'd probably need more like 15' to get the antenna itself above the peak. I think between the 4-6" push from the wall and and Scantenna itself I think it should be OK if the antenna is not actually above the peak...
A few basic questions...
- What distance should there be between the wall mounts? I've read 20" is the minimum... but is there a rule of thumb based on mast length?
- Is there a rule of thumb for how much mast should be sticking out of the bottom mount? How about how much should be exposed at the top beyond where the antenna has been mounted?
- As to the mounts themselves... I don't have an extension ladder that reaches as high as this window... I'm confident I can get the mounts installed by leaning out of the window, but can I reasonably expect to mount the antenna to the mast, get the mast+antenna assembly out my window, and then the mast into the wall mounts? Or is that crazy? Seems like with an antenna at the end of a 10' mast I'll have a lot of weight, plus the leverage will be working against me...
Another option is that I could put the wall mounts about 6-8' below the window (that's about the max working height of my ladder) and then use a very long mast from there to the peak... if I did this I was thinking I could mount everything from the ladder using the two holders, and add a third mount further up the wall by leaning out of the window. I think that would be quite strong, but would look fairly ugly on the side of the house because it would be something like a 20' pole the majority of which would be along side the house rather than majestically soaring into the air carrying my fabulous ~8' antenna
Thanks for any tips...
