Want Disney Dmr Freqs ?
dave3825
New York
#3
I am aware of the RAS mode, I was asking if the freqs were correct? I never saw a set up like that..
K4SVT
Banned
#4
Still encrypted...you aint going to hear it.
Sent from my LGMS631 using Tapatalk
jcardani
Orlando, FL & Ocean City, NJ
#5
WDW is Linked Capacity Plus so there are 2 channels per repeater frequency (1 for each slot). Channels 1&2 are for repeater 1, channels 3&4 for repeater 2, etc. Uniden calls this channel naming method "Logical Slot Number". Uniden decided to use the Logical Channel Number instead for simplicity. So LSN 1&2 are LCN 1, LSN 3&4 is LCN 2, etc.
Anyway like K4SVT said they are totally encrypted and using RAS.
UPMan
Uniden Representative
Arlington, TX
#6
Site 6 is not properly channelized. I suspect someone used the LSN's from DSD+ to submit them. RRDB should have LCN. For Site 6, the LCNs should likely be 5, 6, and 7.
jcardani
#7
Just checked my notes. Most frequencies in the DB are incorrect and for the ones that are they are not the correct LCN#.
WDW is UHF Linked Capacity Plus with 14 sites. Most major sites have 7-8 channels each (14 talk paths).
This system is extremely difficult to figure out because of the extensive use of Part 22 (454 MHz frequencies) which are licensed to a geographical area. In other words the license will not tell you the location of the repeater sites or even the actual frequency (it's a range of frequencies).
In addition Universal Florida uses a 900 MHz. Connect Plus system and also has Enhanced Privacy on all talkgroups.
The only park in Orlando that is clear is Sea World. They are 900 MHz Connect Plus.
HTH
K4SVT
Banned
#9
Yeah well i heard it was AES-256 which is supported by MotoTRBO..moving on..
mikewazowski
Staff member
Central Ontario
#10
Unless things have changed since March, they were using Enhanced Encryption.
AES is supported by MotoTrbo but getting Motorola to sell it to you in North America is tough.
* And it's been confirmed from someone in the area, Disney is still using EP *
