Pro106 Message
I'm trying to sync my Pro 106 and I keep getting this message "warning: one or more talkgroups are not assigned to a trunk system!". I can't get anything to sync to it. I'm new at this and I can't figured it out, any help would be appreciated.
Before I attempt to provide assistance, I need to know what you mean by "sync."
Most of the time, when I've seen messages on the screen of my radio, it generally showed the presence of a "heap error." From what I've understand about this, it means the TSYS (Trunking System) is unattached to the associated talk groups (channels). I might add, the only time I've seen this error message was after I attempted to manually program my digital scanner. I hardly ever make mistakes using Win500. When I do, I can go into the radio & WIn500 to see if all trunking systems are attached to talk groups.
The TSYS and Talk groups have to be attached to one another before the radio will work.
Again, I prefer programming my radio with Win500. It saves tons of time and you have a much larger visual field to review instead of the limited view in the radio's LCD screen.
Here are some links:
Easier to Read Pro-106/197/PSR500/600 Digital Scanner Manual
WIN500 - UtahRadio
After review, post another response. Then, we will hopefully work this out.
