Warrick Co. to Upgrade Spotty Emergency Radio System
Southern Indiana
#1
Warrick Co. to Upgrade Spotty Emergency Radio System - NEWS 25 - WEHT: Evansville, Henderson, Owensboro-
Posted: Dec 18, 2009 9:50 PM Updated: Dec 18, 2009 9:50 PM
story by: Corey Allan
BOONVILLE, IN - A faulty radio system for Warrick County emergency crews has left many dead zones across the county. A situation so bad dispatchers and deputies can sometimes barely make out what each other is saying.
However, the county plans to upgrade the system by adding two more towers and converting to an 800 megahertz radio system.
"There's a lot of areas…when you're on a portable radio and you just can't communicate," said Warrick County Sheriff's LT. Paul Weinzapfel.
Weinzapfel says most departments in surrounding counties already use an 800 MHz system, which gets calls faster than the county's current 400 MHz.
"Officers should have coverage anywhere in the county. And good coverage too," Weinzapfel said.
The project will cost over $1 million. The Warrick County Council has agreed to pay half the annual cost – about $60,000.
Equipment improvements will be seen, and heard, in about six months.
