Washington, DC - Public safety radio system must happen
BrigPilgrim
Wisconsin
This sounds great in theory, but the systems I have seen proposed give everyone the capability to talk to everyone else. Resulting in systems that are too complicated and expensive for use on the line. If I have a radio to call out to the truck for a piece of equipment, should that radio be able to talk to the Governor to call for the National Guard too? The systems get too complicated for anyone to decide on and we end up with decision grid lock.
Instead of trying to completely reinvent the wheel, they could get this done if they would design a better Command network and use the existing systems for operations. Look at the problems you have in a centralized 911 center under heavy traffic. In a severe storm you lose the capacity to dispatch crews to fires because people use the same system to call in downed trees and lost dogs. Centralized communications often turn into a tower of Babel because we forget the rule that "there is no such thing as an emergency, it is your job".
ab3a
Lisbon MD
It would be better still if they'd learn a few pro-words
OK, so we connect everyone to everyone. Will anyone be able to understand each other? How many variants of the ten codes are there? How many silly made-up phrases does each county have? I've heard "Everything is 'Ocean King'" on the air with some counties. I've heard others say "copy direct" on a trunking system.
These is insane. And now we want them to talk to one another when they can't even use the same phonetic alphabet.
One might as well speak Farsi to a Portuguese speaker.
MTS2000des
5B2_BEE00 Czar
We've already spend 7 billion since George Bush promised to make us all safe with SAFECOM on new toys.
You can spend a hundred billion on hardware and it isn't going to make groups who don't have a need or desire to talk to each other on a radio to do so.
It's like going out and buying the latest I-phone, or Droid...doesn't matter, you try to give a girl your number. If she doesn't WANT to talk to you, does it really make a rats behind difference what phone you have? It isn't going to MAKE her call you.
