Washoe County System New Control Ch's
Ka2hxu
Reno,NV
Recently Washoe County around Reno area changed there Trunk Control Channels to
Update the area Band Plan.
Does anyone have the New Control Channels ??
TheRichman
Reno Nv
Control channel
I too live in washoe county and discovered that my Bd250D scanner isn't working, but my new Bcd396 xt works just fine , if you find out let me know, like wise if I find out I'll let you know.
E-mail address is Therichman@sbcglobal.net
1st try the SEARCH feature on youir scane r& look, 2) ask in the NV forum for better chance of getting an an answer:)
Ka2hxu
Reno,NV
So,all in all, You subtract 15 Mhz from the Old Channles ! That's It !
So if you have 866.2750 - 15 Mhz gives you 851.2750.
sigint1
Was: joking
Mostly yes but it actually depends on the frequency - there are some sites (Slide Mountain) for example that had some 860.xxxx freqs that are in the expansion band and were not changed (take 15 from 860 and you end up in the 845 range which is cellular) - the agency (if it was public safety) had the option to keep theses freqs or get issued different ones - so some were kept.
