Waterford Works 171-30
robnj74
Buena, NJ
I stumbled upon this while looking for another site but I can't find the frequency on their license ( WPMV796 ). Is this something that needs to be added to the database ? I would try to monitor it with my 436hp ( I have DMR,NXDN, and Provoice activated) but I'm not experienced enough to know how to program frequencies outside of Sentinal.
Rob
K2RJJ
GTR8000
NY/NJ Database Guy
BEE00
499.893 is not a valid frequency. Did you set the frequency correction for the dongle in SDRSharp? Most likely the signal is actually in the 501 block and is part of this license:
Try searching those frequencies with your scanner and see what you can find.
robnj74
Buena, NJ
I bet it's 501.8125. I'm about 6 miles from Waterford Works and that comes blasting in here.
Yeah that's what it appears to be, somehow it was in there twice till I cut the sample rate to 1.92msps.. sorry about that..
GTR8000
NY/NJ Database Guy
BEE00
There have been changes to some of the NJ sites of the OneVoice system. If Waterford Works is now using 500 MHz channels instead of/in addition to 470 MHz channels, please check the site out and submit any changed required.
Skypilot007
Medford, NJ
I have system 171-30 on 501.9625 as of right now with neighbors listed as 171-28, 171-31, 171-36 and 171-38.
The same system is also showing on 471.9625 with neighbor listed as 171-29, 171-31, 171-33, 171-34 and 171-35.
That's all I could hear from my location.
robnj74
Buena, NJ
2 questions, how is a change submitted and in this instance how would I report a new talk group when I can't identify it because it's encrypted..
u2brent
OAMPT
KRWDPAXKRS1
You can't submit an unidentified encrypted TGID, But you can find/add to the wiki if it's not already been reported..
In some circumstances; Even if you know what it is with 100% certainty the admin may not accept it.
GTR8000
NY/NJ Database Guy
BEE00
Yeah, I'm not surprised...system is in flux as apparently some of the radio shops in NJ have split off from the main system and are doing their own thing now.
Is 471.9625 also reporting as Site 30? What a mess.
robnj74
Buena, NJ
Wasn't aware there was a seperate wiki for that, thanks for the info I do appreciate it.
Rob
K2RJJ
Skypilot007
Medford, NJ
Yes it is.
