I trust your word that the sensitivity of M-RKs is quite good, but haven't had a chance to
try one out for myself.
However, when I went to do sensitivity tests on some Jaguar 700Ps and 7100IPs as well,
I was...well....stunned by the results.
My test signal generator is a Rohde & Schwarz SMY-02, which works down to -140 dBM.
It's a 15,000 dollar piece of equipment. (Retail when it was new, not very many years ago.)
The radios were able to pick up the LEAKAGE from the signal generator with the RF output
turned OFF.
So I had to go to a custom solution to keep the radio from picking up the stray radiation,
and keep it in the test cable all the way to the radio.
The radios would reliably break squelch between -127 dBM and -135 dBM.
That's EXTREMELY sensitive.
However....comparable MOTOROLA radios, while not being so quick to break squelch,
achieved full quieting more quickly. At a signal level where an Astro Saber has just
hit 20 dB quieting or full quieting, the M/A-com radio was receiving the signal but with
a little more noise mixed in.
Elroy
