Web Service Question, Pro-92
pcexhaust
Win92 is what I've been using to manually program the scanner now. Am I stuck with this method until I upgrade to a better scanner?
gmclam
Fair Oaks, CA
There's a PRO-92 group on Yahoo. Perhaps you can find an .spg file there with what you need programmed. Personally I like to customize my stuff anyway.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
The wiki contains a procedure that you can use to copy/paste data using Excel (or similar) as an intermediary...
http://wiki.radioreference.com/index.php/Excel_Copy/Paste_Special_to_Software
In addition to the PRO92 Yahoo group, you could also try your state's forum here on RR, or alternatively, one of the many scanning related Yahoo groups for your state. A good assortment (not necessarily complete) are indexed here...
http://wiki.radioreference.com/index.php/US_Scanning_Mailing_Lists
73 Mike
[edit] If enough folks complain about the lack of the web service support, perhaps DonS will relent and add it to Win92, 93 and 95. It would probably be easier to make it a plug in rather than integrate it....just a thought....
pcexhaust
Thank you all for the information. I requested to the join the PRO-92 Yahoo group and the Excel wiki article will help.
Thanks again
