Webb county database update
Albert_950
laredo,tx
I was in discovery mode and found several new TGIDs: site Laredo Public Safety TGID (3062) unknown who it belongs to.TGID (1505) unknown who it belongs to I did figure one out: it is UISD police dispatch TGID (2002) that is not posted in RR already submitted that one to RR. The other one is in the Webb County simulcast TGID (46261) unknown who it belongs to. My question is how do I figure out who it belongs to or is there someone here that can help me out?
Hopefully someone from the area can help you, but in the meantime let me share some tips.
Listen for addresses and the type of dispatches or conversations. If they are talking about fires, medical or law enforcement information that would be a good key, addresses will help you identify cities or sectors.
Another suggestion, depending on your scanner is keep track of Radio IDs, if radio 123456 is heard on an unidentified or encrypted TG and you see the same or similar RID on a known TG, then that is a good indicator.
In short, it takes lots of listening, logging and cross reference.
Thanks for the tips. Is the RID similar to UID? I have a sds100
Yes, Whistler calls it RID (radio ID), Uniden it is UID (unit ID).
Consider using a logging software like PROSCAN to make it easier to sort and review lists of the UID from comms when you aren't home, or too busy with life.
Tony_STX
Webb County talkgroups under GATRRS has TG 6261 as Special Events 1. It may be that one but on the new system? You would just have to continue listening to confirm it.
Albert_950
laredo,tx
Thank you for the advice, but as of now, it comes out as encrypted. It’s going to be hard to determine whose department it belongs to.
medic3004
There isn't much to listen to in Webb County anymore. Ever since SO went encrypted its been pretty boring.
Tony_STX
I have picked up very sporadic traffic in the clear on TGIDs 46261 and 46210. 46206 is fully encrypted and 46296, which is Webb Fire, is in the clear.
Tony_STX
I can hear it in the clear. Very sporadic traffic though. I just can't figure out who it belongs to.
Albert_950
laredo,tx
I agree. I wonder if it’s due to the reason of being a border town.
Same here. I have not discovered 46206. I’ll give it a try as well to figure out who it belongs to. Also, tgid 46232 is another one I’m trying to figure out. Keep me updated if you find out. If I find anything, I’ll post it here.
Albert_950
laredo,tx
46210*** I have not discovered correction***
Albert_950
laredo,tx
hello, any updates on those tgid.TGID 46210 I believe it belongs to a special tac of sheriffs assisting troopers and bp close to the river (downtown outlets) and (by lc south)
Tony_STX
From when SO was using GATRRS, when an SO unit was dispatched and responded to a call for service it was always a 5100+ unit number. I have yet to hear a 5100+ unit in the clear on any talkgroup. Even 46210. Which leads me to believe SO went completely encrypted. I know constables precinct 3 units are in the 500 range from when SO would ask for their assitance or vice versa. I hear 600 range units in 46210. I don't know what dept those belong to.
memo124
Edinburg Texas
Have you tried searching VHF band. I know that they patch the frequency to the GATRRS system when they were using it.
Tony_STX
Yes. Webb County no longer uses GATRRS at all. Only GATRRS talkgroups I pick up are La Salle County and Del Rio DPS (sporadically).
Albert_950
laredo,tx
Yes. Webb County no longer uses GATRRS at all. Only GATRRS talkgroups I pick up are La Salle County and Del Rio DPS (sporadically).hsvr ysll
Have y’all experienced any difficulties with the dps from Laredo base D. I know they’re p25 VHF. Whenever I am at home it works fine but as soon as I move around with the scanner it cuts off and once I get in a moving vehicle it doesn’t catch any activity at all. I have the sds100. Is the scanner not picking up VHF or whst can it be.
medic3004
I haven’t heard much of DPS they used to be a lot more active. I use a sds200 for my truck. I use an external antenna mounted on the window. It gets more reception than my old antenna.
Albert_950
laredo,tx
What antenna do you use? I I have also seen the ones that mount next to the hood as well.
Tony_STX
DPS in Laredo has poor handheld coverage in the city. You need a roof mounted antenna to pick up activity. I think their tower is a couple of miles outside the city limits on I-35.
