Westrock/Westvaco Covington
Piedmont NC
#1
Been doing some work in the Covington area lately.. I have monitored a bunch of frequencies for the Westrock Plant in Covington. All has been VHF with the exception to 462.450 131.8. Lots of general maintenance traffic on that channel related to fire alarms, so I am assuming that is a shared Rescue Squad/Fire Brigade channel (listed as Westvaco Rescue in the DB).
Anyone have any idea where Security is hiding, or if they are on the same channel with Rescue/Fire?
Thanks!
n4jri
Richmond, VA
#2
I've been in Covington a number of times, and little to no luck on WestRock. Actually stayed nearby at the little motel right by the bridge to 60 West. Have had no luck, but plant security may actually be security/safety and use 462.45 that you found. At some plants, security deals primarily with access control, and patrols may be minimal or uneventful. In Hopewell, you'll hear very little on security freqs for WestRock or AdvanSix. At the WestRock plant, gate security simply uses an all-call TG to announce when a train is entering the plant.
Also note that WestRock tends to use DMR most places I see them. Are you hearing masking on any of the freqs you're monitoring?
73/Allen (N4JRI)
Piedmont NC
#3
Everything I am hearing so far is analog. Was able to locate the following by programming in all the licensed frequencies:
152.4500 233.6
152.4650 141.3
158.2950 131.8 (152.8850 131.8)
152.2850 123.0 (153.0650 123.0)
150.8525 67.0 (157.4925 67.0)
462.4500 131.8 (467.4500 131.8)
Prince George, Virginia--Central Va.
#4
73/Allen (N4JRI)
Allen,
I agree. My database showed WNOF844, 462.450 mhz., repeater as "Security" for the previous analog WestVaCo operation listed at least 10+ years ago and the emission changed at least a year+ ago to show DMR Analog/MOTOTRBO West Rock, Covington.
John
W4UVV
