Wha Happen?
ampulman
South Jersey
This AM, a new system (Camden County P25) appeared in the DB. I entered it into my 396T, but no normal activity noted.
Just checked the DB about 4:50 PM EDT and the system was not present.
Anyone know what happened?
On another note, this is the first P25 system that I am monitoring. When holding on the system, there is no 'control channel sound'. If this typical for P25 systems, or is it due to the fact that it is not doing normal transmissions?
There were 2 TGs noted (testing only) in the DB, but the system was not indicating any TG activity. When holding, the System ID and Site information, along with a DAT indicator, are shown.
Any info appreciated.
Amp
nd5y
Wichita Falls, TX
When holding on a P25 control channel the 396T mutes the audio. You won't hear anything.
If it is decoding the control channel the display will show LNK or DAT, SID and any active talkgroups. Pressing the Func button will show WACN isntead of SID.
W2SJW
Senior Member
Northwest NJ
The system is in 'staged' mode right now - once more confirmed info comes down the pipe, the admin that staged it will make it public. The test site data shows 800 MHz channels, but this new system is supposed to be 700 MHz when deployed...
ampulman
South Jersey
Thanks for that info. I will keep an eye on it and report any findings.
Amp
Skypilot007
Medford, NJ
I'm not seeing the new system in the database. Was it removed. Can someone post up any information they have on it so I can program it. Thanks...
jcardani
Orlando, FL & Ocean City, NJ
FYI,
Unitrunker shows that the system is TDMA. Not sure if that means TDMA capable or that it will be TDMA only. The latter is not good news for scanner owners for sure.
Audiodave1
Chadds Ford, PA
Here is the known system info.
System Description: Camden County, New Jersey
Callsign: WQJZ399
Site:Lindenwold Frequencies
854.3625 CC
854.1875 Alt CC
854.1375 Voice Channel
TG 101,102 were heard active with techs.
Dave
jcardani
FYI,
From Unitrunker (the person): When TDMA is shown in the Unitrunker program it means the system is TDMA capable.
ampulman
South Jersey
Camden Cnty need for non-monitorable system
In listening to Camden County transmissions (not including police) over the years, I have heard any tnx that required 'privacy', but understand their need for that capability.
Even the EMS units reporting patient info on the hospital band, do so in a non-identifiable manner.
So, we can only hope.
Amp
ampulman
South Jersey
Callsign: WQJZ399
854.3625 CC
854.1875 Alt CC
Dave
I'm confused. What is with the 'voice channel'? Is this a discrete frequency 'outside' of the control channel's pervue? My impression was that P25 systems were 'control channel' only. My scanner (396T) does not offer a CC only option for this system, which seems to support that.
I only programmed the control/alternate frequencies. Should the VC be programmed? I have not heard any audio while monitoring this system.
Amp
bezking
On the Road
The Voice Channel is the channel that actually carries, well, the voice of the people using the system. Control Channel Only means the Scanner will be told by the TRS where the channel is, as opposed to the user having to program every voice channel into his scanner.
The Control Channel exists to point the Radio Users to a free Voice Channel, where they can send and receive voice traffic.
HTH
ampulman
South Jersey
So, are you saying there is only one voice channel? Kind of negates the need for a trunked system
I agree. My comment should have stated that (I believe that I read somewhere) P25 systems are, by default, CC only.
Again, I agree. So, what is the purpose of including a single voice channel information. Is (was) this the only voice channel being used up until now? If I don't program it, will I hear any traffic?
Amp
Skypilot007
Medford, NJ
I haven't logged a single hit in 2 days on this system. Not much testing going on lately I suppose. Anyone else hear anything?
ampulman
South Jersey
Would like to know approx. time of day, you heard it. Also, was this a brief transmission, or was there continued back and forth?
So, what do you typically hear during the testing phase. Is there a mobile unit running around asking the base if: "Can you hear me now?......good".:lol:
Amp
bezking
On the Road
There are probably more. The fact that only one voice channel was used only means that one voice channel was needed, this does not necessarily mean that only one voice channel is available...
Yes.
As long as you set the system in your scanner to CC Only, you shouldn't have to program the voice channel.
HTH
