What antenna connector is this?
RenoHuskerDu
Longtime VFD, rusty old scanner
Bertram TX
What antenna connector is this? The diameter of that O-ring outside the brass is similar to NMO. That's a UHF on the left for size comparison. It's on a little magmount I got for free that had a zero-gain 4" can, which I discarded.
I want to find a 1/4 wave 450MHz stinger to put on that little mag base instead.
RenoHuskerDu
Bertram TX
That's an NMO mount that has come apart.
The brass ring in the base of the antenna belongs on the mag-mount.
By Jeeves, you're right. I just looked at the silly little can that came off there and it's clearly NMO.
Now it's surgery time ...
Thanks gentlemen
mrweather
Interesting that the centre pin is threaded like that. I would've thought they'd be pressed in.
arlo
That is a mount for thick metal. Not paper thin sheet metal. Just the mount is a PCTEL BMATM38.
