gcheno said:It looks like an antenex whipless VHF antenna.
Here's a picture from the website:
jonny290 said:these things better have some magical radiating properties, cause i'm about to laugh at somebody for running a coil of wire for a VHF/UHF antenna if these antennas aren't awesome.
I see no reason why to even bother with a 'low profile' unless you're trying to work undercover, in which case you're using handhelds most likely anyways.
jcecklund said:That antenna is used of MDT on the laptops. It is an 800mhz low profile.
Grog said:That looks way to large to be the UHF/800/900/1900 size. It's a VHF
BTW, my compant uses maxrad wide band antennas for data, they cover the full 800/900 band and the 1900 PCS band as well.
Dubbin said:Its a cop antenna on a cop car with cop lights, cop motor, cop tires, cop suspensions, cop shocks, cop radio.
Grog said:Can't be, that's a ford. I thought real cop cars had 9C1 in their discription? (and built between 1994 & 1996)
Secret_Squirrel said:The Antennex Phantoms....The biggest issue I would think would be what you touched on. They are unity gain and a person would think that one would be better served by a better antenna with some gain. I guess they have their applications but still, I'd rather just use a whip of some sort for my applications.
