What are people using?
Northern Ontario
#1
I am curious to know what people are using out there?
I am running ID Tracker V1.5.1 on a Inspiron 5100 using my PSR 500 with a splitter. One line records and the other feeds speakers.
I also run Trunk88 V4.84 on my Gateway Mseries laptop feed by a tapped Pro 70
I monitor my local businesses with my Pro 26
Let us know what you are using.
Gulf Coast
#2
No P25 systems close enough for me to monitor currently, and I've not had much luck getting any of the other programs to utilize the data port of my Pro-106 for data software info, I'm not using too much in the way of software with my radios. The only thing I'm using right now, software wise, is PSREdit500, which I use to both control and program the radio. Since my area is still primarily all vhf, I also use the radios listed in my signature for monitoring specific agencies.
