What are the tampa police agency/fleet/sub fleet codes?
Greg43545
NW Ohio
I am programming my scanner with the Tampa PD frequencies for the upcoming Republican National Convention next Summer and I noticed that they run an EDAC system, but I cannot find the agency/fleet/sub fleet codes to put into the slots so I can monitor them while trunked.
Can anyone provide me with the agency/fleet/sub fleet codes that go along with the following frequencies?
Tampa Police Frequencies:
453.55000 , KIB459 , RM, 94.8 PL, TPD 1 , Police District 1 Sector B (South of I-275) , FM
453.70000 , KIB459 , RM, 94.8 PL, TPD 2 , Police District 1 Sector A (North of I-275) , FM
453.80000 , KIB459 , RM, 94.8 PL, TPD 3 , Police District 3 Sector F , FM
453.85000 , KIB459 , RM, 94.8 PL, TPD 4 , Police Tactical (can be patched to Hillsborough County TRS) , FM
453.75000 , KIB459 , RM, 94.8 PL, TPD 5 , Police Records , FM
453.87500 , KIB459 , RM, 94.8 PL, TPD 6 , Police District 2 Sector C/New Tampa , FM
453.32500 , KSX313 , RM, 94.8 PL, TPD 7 , Police District 2 Sector D , FM
453.50000 , KGJ903 , RM, 94.8 PL, TPD 8 , Police District 3 Sector E , FM
458.73750 , KIB459 , M, 94.8 PL, TPD 9 , Police Tactical , FM
460.51250 , KB77870 , M, 94.8 PL, TPD 10 , Police Tactical Response Team (TRT) , FM
460.11250 , KB77870 , M, 94.8 PL, TPD 11 , Police Special Squad , FM
458.26250 , KIB459 , M, 94.8 PL, TPD 12 , Police Tactical , FM
458.93750 , KIB459 , M, 94.8 PL, TPD 16 , Police Tactical (Stadium Events, Handhelds Only) , FM
453.96250, WPBR248, M, 94.8 PL, TPD Air Police Air Service , FM
clawhammer
West Central Florida
Greg43545
NW Ohio
The frequencies you have have below are no longer used by the Tampa Police, they are now on the Hillsborough county Edacs system. if I understand you right you are looking for the AFS for Tampa PD on the Edacs system. they can be found under the data base. here is the link. hope this helps you out.
Hillsborough County Public Safety Trunking System, Hillsborough County, Florida - Scanner Frequencies
Thank you for that info.
So correct me if I am wrong, Tampa PD is now using the same EDAC freqs that Hillsoborough S.O. is?
Since I already have the Hillsborough Co. S.O. West System frequencies set up in my scanner with the appropriate agency/fleet/sub fleet codes programmed for HCSO District 3, what do I need to do to program the Tampa PD agency/fleet/sub fleet codes?
Do I need to re-program those frequencies into another bank, and then put in the proper Tampa PD agency/fleet/sub fleet codes?
If so, which EDAC freqs. do I put in, the East Sysytem or the West System, or both?
abbadabbado
port richey
tampagreg i put in both east an west systems two seperate systems then on the west system lock out all except tampa pol an frie resc one system for hills one system for TPD works fine foe me
Greg43545
NW Ohio
Since I already have the Hillsborough Co. S.O. West System frequencies set up in my scanner with the appropriate agency/fleet/sub fleet codes programmed for HCSO District 3, do I now need to re-program the scanner again with the same frequencies this time for the bank of Tampa channels and agency/fleet/sub fleet codes?
If that is the case I don't know if I can do that since I have an Older Uniden Bearcat Trunk Tracker II BC245XLT.
I know that I cannot enter the same frequencies twice, no matter what bank I attempt to do so, because I will get an error message if I do (been there and done that).
Any suggestions?
