What are Unication pagers intended for?
Sydney Australia
Hi all,
never ever heard of Unication pager’s before I started using RR 6 months ago. What were their initial use.
I don’t think they were bought to the market for comm’s enthusiasts but more for EMS workers so they can keep a ear on what’s happening at home.
Maybe for part time or volunteer’s EMS workers aswell.
Any information would be appreciated.
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
Back when the earth was still cooling and us volunteer firefighters were riding dinosaurs to fires, we carried pagers (or, sorry, "tone receivers") which were parked on the one analog frequency our department used, and had physical plug-in pieces that were tuned to our specific alerting tones. These worked beautifully for the purpose for which they were designed, and many of them lasted for dozens of years (though as with everything, more than once I was handed a pager that a firefighter had managed to break or drown, despite their near-indestructibility). As technology advanced, so did the pagers, with programmable software-defined alert detection and etc., though the later ones paled in comparison to the original devices.
When trunking came along and fire departments started migrating to those systems, firefighters (and EMS, rescue squad, search and rescue, and others that used the tech, as you suggested in your post) started asking manufacturers to develop a 'trunking pager'. The response was invariably 'yeah yeah, we're working on it, you'll see it at the trade show next year, it's gonna be great'. Same thing was said over and over year after year, and continued when digital comms began coming to the fore. The old pagers, even the latest versions, were only good for analog 'conventional' (non-trunked) channels - to the point where even today, some agencies specifically maintain an analog conventional channel for alerting, which may or may not be patched to their trunked system.
Unication were the ones who finally developed a 'pager' that followed a trunking system. They still basically do the same thing - they listen to a radio channel for a specific set of tones, and alert the user when those tones go off, and play (and/or record for later playback) the audio that immediately follows the tones. As you say, they weren't intended for scanner hobbyists, but they are a relatively less expensive option for monitoring a digital trunk system compared to the modern scanners which will cost much more.
kc5igh
Velarde, New Mexico
Beautifully written, description, Jay 911!
The only thing I'd disagree with is your comment that Unication pagers are "a relatively less expensive option for monitoring a digital trunk system compared to the modern scanners which will cost much more."
In my experience, Unication pagers (at least, the G-Series) are more expensive than other modern scanners.
I'd also add that linear simulcast modulation (LSM) was one of the issues that made them very popular among scanner hobbyists. The only consumer-grade scanners that can reliably receive LSM transmissions are Uniden's SDS-100 and SDS-200 models. The Unication pagers excel in that field.
-Johnnie (KC5IGH)
jabbeaux
Germany
Ah yes, I recall it well. That period was just after the fire and brimstone age, when we listened to the intervals of the horns then could "decode" the horn intervals using little notebooks to give a little info on the alarm.
Ah, a time when men were men, horses pulled steam engines, and "emergency lighting" meant a lantern with red glass.
peteymcsweety
cincinnati. Ohio
I would put unication pagers as best monitor of simulcast systems and yes even better than uniden sds100 and 200 so you would think that scanner manufacturers would get on board with unication and make a radio that would satisfy the hobbists needs....
Sydney Australia
Even Motorola proposes Unication pagers for some of their system bids when P25 paging is desired.
I know the Unication pagers are IP-67 water and dust proof, not sure about fully Mil-Spec? Actually if you changed the Unication emblem to Motorola, many wouldn’t even know the difference.
I just reread Jay911’s comment which is second comment from the top and noticed under his name’s description it has Silent Key (April 15th 2023), so his passing is 14 days after his comment. I want to say by going on what he wrote in his original comment it shows Jay was a character. I didn’t know the man only through RR comments. VALE Jay and thank you. R.I.P. Sir.
tkowalik
Banned
In some cases, Unication Pagers are used by civilians to test whether or not they are a viable, cheaper alternative to wasting taxpayer dollars on radios that cost 10x what the ‘standard’ costs.
Put that one in your notes.
sefrischling
Public Information Officer
New London, CT
How is that even possible?
The Unication Pagers, of which I have the G3 and G5 for work, are not radios. They do not do the same thing as a radio, they are only one-way, inbound, receivers. They cannot in any way replace a "standard" two-way radio.
N6ML
Well they *are* radios. They are not *transceivers*.
Some personel don't need to transmit - they just need to be made aware that an incident has occurred, so they can respond (possibly picking up a transceiver from a station after they travel there from home, etc.).
sefrischling
New London, CT
The comment above is "Unication Pagers are used by civilians to test whether or not they are a viable, cheaper alternative to wasting taxpayer dollars on radios that cost 10x what the ‘standard’ costs."
... what civilians are testing the Unications to see if they are a cheaper alternative to wasting taxpayer dollars? This whole statement makes no sense. Are the civilians on some town's commission? Are there civilians seeking to take over a public safety agency's communications? What is the baseline for testing? What is the end use of the unit?
In my department we have pagers, they are for alerting, they can in no way replace the ‘standard’ radio, as is referenced above.
N6ML
Don't know about the civilian part of the statement - indeed that doesn't seem to make much sense. I was more focused on the assertion that pagers are not radios, which is a matter of terminology.
jeepsandradios
East of the Mississippi
Even with P25 a lot of analog paging systems get upgraded and installed every year.....At least on the east coast its still a big thing with volunteers and some career folks.
sefrischling
New London, CT
My department is a combination department, as we transition to P25 Phase II within the next year we'll keep VHF analog for paging. The rough plan is to keep conventional in place for about 5 years, of course that can change, but the cost of switching and replacing all the pagers is just too much up front.
maus92
The OP
Very common in the NCR to retain VHF analog paging even though virtually all radio systems are 7/800 trunked simulcast, and almost all are some flavor of P25.
