Hi guys,
Here goes "the quicker picker upper" again cleaning up the mess. (;->)
You didn't need the pictures, few antennas come with anything but SO-239 or N connectors.
"Yep, it's probably an "N" type....Lower loss at higher frequencies than the UHF type..."
Not really, it's a constant impedance connector, the PL-259/SO-239 combo is not and that slight difference makes NO difference except at low microwave frequencies.
"...but somewhat more problematic finding a run of coax with an N type male on one end to fit your antenna."
Not at all.
"Your local Radio Shack likely will not have anything like that."
At Radio Shack you have questions, we have blank stares.
"It might be possible to use some sort of adapter to convert the N female down to an SO-239 but I would advise against it..."
So do I.
"...the insertion loss from that kind of arrangement would defeat the purpose of having an N female antenna connection in the first place."
Not at all, the mechanical mess would defeat the purpose.
"Places like "the rf connection" and "cable experts" can whip you up a coax assembly with the connector you need at pretty reasonable prices."
A soldering iron is a much wiser investment. Learn to make custom cable assemblies yourself and be free of the prepackaged waste and high prices.
"But I will take your advice anyway in case I decide to move it ouside."
In that case you need to learn how to apply Tommy Tape, the best invention since the bread slicer. Come to think of it, a bigger version is a tape slitter.
"I hate adapters and refuse to use them."
They hate you too, when was the last time you were used by an adapter?
