What Else Can I Scan in LA County?
OneBadUukha
Los Angeles, CA
#1
I've spent a lot of time setting up my scanners to receive solid, organized, and trackable transmission from the following agencies:
- LAPD
- CHP
- LASD
- LA City Fire
- LA County Fire
It's been great, but I'm looking for other agencies to monitor or scan. I bet some of you more experienced listeners have found other, lesser known channels that are compelling. Can you recommend other agencies? Thanks.
allend
Long Beach, CA
#3
You should add all of the South Bay cities with regards to their LE conventional channels and Fire.
Also, add LAX Police. 460.1 is their P25 Control Channel. Phase 1 FDMA System
