What guage wire should I use for this 12v outlet?
Stimpy911
I am going to direct wire this to the battery but I am not sure what size wire to use. Can anyone take a guess for me?
mikepdx
Corbett, OR USA
------- # 14 or 16 probably.
Be sure to fuse it.
Don't plug in anything with a high
amp draw like a transmitter, motor,
heater, etc.
If it's just scanners, cell phone chargers
and low amp draw devices, you're good to go.
jim202
New Orleans region
The real answer lies in what your going to do with the outlets. What type of current draw are you planning to pull? Once you know that, you can add up the different outlet draws and get a total current drain. that then will translate into a wire size that you can find from a simple search on the internet.
Just don't forget to fuse it, based on a current slightly higher than your intended draw. I would suggest not to use an inline compression fuse holder. the reason being that with time and heavy current draw, the springs have a tendency to loose their tension. this causes the connection to be loose and burns up the holder given enough time and current being drawn through it.
Stimpy911
Cell chargers
Galls led dash light for ems
I also have a light bar that draws 10 amps. Its connected to a cigarette plug. Was using that temporarily until I direct wire it to my switch box
I'd add that you not only need to know the expected maximum current draw, but you need to know how long the wire will be to reach the battery. The longer the wire, the more voltage drop. To reduce voltage drop, you'd need to increase the size of the conductor.
Cell chargers
OK, so let's say 20 amps total. Conductor length around 15 feet. I'd run #10. That should be around 3% or so voltage drop, which is more than acceptable for these sorts of loads.
#10 will also give you some headroom. Fuse it for 20 amps, but the wire will support more than that.
Also, be sure that plug array will support that much current. Some of those things are pretty cheaply made.
Stimpy911
Maybe I will look on amazon for something new. This is old out of an old squad car at the PD I volunteer at. Any brand suggestions on amazon?
prcguy
I would also use #10 since it will keep the voltage drop within a reasonable range for 20A and its small enough to bend and work with. I would fuse it at 30A right at the battery or better yet use a circuit breaker designed for under the hood use.
prcguy
I don't know of any "good" ones. Cigarette lighter plugs are not the best choice. I don't ever use them for anything permanent, especially any sort of emergency lights. Cell phone chargers are all I ever use them for.
Any chance you could run a #10 to a switch box and do a more permanent install?
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
I have a couple of those in my junk box. The sockets are incredibly flimsy and poorly assembled inside. If I was going to use one for anything that draws more current that a cell phone charger, I'd open it up and re-flow all the joints plus check for adequate size wire inside the housing.
I would also suggest that using supply wire larger than the original might not be the best idea. I'd be much more conservative here, suggesting #14 wire at most and a 10 amp fuse at the far end.
CM1
Central, NJ
The other thing to consider is what gauge wiring is actually inside the unit?
For example if it has low quality (and unfused) 14-16 gauge wire inside the unit ( I took one of these gadgets apart one time and was horrified by the quality inside) and you go plug something (say 20+ amps) into one of the receptacles, that wiring in the unit is going to get pretty warm (hot) very quickly. Not something you want.
Stimpy911
I have a switch box ready to go. I just need to buy a power distribution fuse block. Good point mmckenna. Prob not the best thing to do lol
Stimpy911
Looking at a blue sea systems power fuse block. I should be able to power everything I need from there.
prcguy
If the cigarette lighter sockets are flimsy you can probably replace them. I have some real nice ones with ceramic insulators and large contact surfaces that should handle more current than you would ever need. I think they came from the Dayton Hamfest and will purchase a bunch more next week.
prcguy
ramal121
Lots and lots of watts
Calif Whine Country
prcguy
Those plastic sockets are cheap and contact into them is poor. Above 10 amps they will get hot, especially after dirt and mung collect in them. If you're gonna run lighter sockets, then as prcguy stated, the all metal ones with the ceramic insulator are the best. Plugs fit them nice and tight. AND KEEP 'EM CLEAN!
Electronic Components - Accessories
http://www.amazon.com/Custom-Access...bs_auto_7?ie=UTF8&refRID=0RJB82J8AVNYM0CFKN01
prcguy
I'll have to post a pic but the link that ramal121 gave is very similar. They are two piece with a outer shell that screws on the back to clamp against whatever you drilled the hole in and they have a ceramic insulator with a large threaded stud for the hot wire and a solder tab on the shell for ground.
The ones I got are just the socket and shell with no mounting bracket or wiring.
prcguy
Prcguy what is the name of those
