safetyobc
Hello,
As some of you know my antenna problems from this thread http://www.radioreference.com/forums/showthread.php?t=32574
I am curious to know what caused tiny holes to form in my coax? The holes were up near the top of the antenna at about 30' high and would be impossible for the antenna to be reached without my knowledge because of location and having to come inside my home to pull enough slack to let down the antenna.
Anyway, a little background. I have a Scantenna up at 30'. I was using the RG6 that came with the antenna and was pleased with it's performance. After some storms rolled through my reception went from 60 miles + to about 5 miles tops. This happened once before about a month ago but reception returned to normal after about a day. I come to the conclusion it must be moisture intrusion.
The second time it happened, I pulled the antenna down and gave it a good look and noticed that my coax had tiny holes (pin size) from the antenna connection to about 3' down from the antenna. I am nearly 100% positive no one put the holes in there. It would be nearly impossible to reach this coax without dropping the antenna and as stated above, I would know it.
The holes are all vertical holes. Like if I were standing above the antenna and punched holes downward. There are between 75 and 100 to 150 holes in the coax at random spacings.
Could it be that moisture got inside the coax and these holes are were it vented itself once the coax was heated by the sun?
Is this some sort of lightining or static discharge?
Any other ideas? I suppose these could have been there when I put the antenna up over a year ago, but I seriously doubt it because I inspected everything really well before installation.
I have ordered some QuadraShield Belden brand RG6 to replace this coax and a new balun. Any ideas on what caused this would be appreciated.
Thanks,
matt
Thanks,
matt
