What is a Source File vs. a Data File?
BirkenVogt
BirkenVogt
In programming 7180s and the like, there is an option to save and load source files as opposed to regular .dat files.
What is a source file used for? What can it do for me?
T0mSmith
Source files are used to exchange channel information between radio models. If you were upgrading from a TK-7160, you could create a source file in KPG-99 with your channel information. You could open that source file in KPG-89 and import as a zone. .dat files store all configuration information for a specific radio model.
SB-Wi
Eastern Dane Co
The data files (.dat) are specific to a model series/software package and the source files are more universal, but not entirely. They can save a lot of time when programming the same setup to different series radios.
From the KPG-89D help file:
Source file is similar to the database and is used for the Merge function. A Source file can store a maximum of 20 Systems in the Zone Merge window.
Zone Merge allows you to store the Zone data in the source file and merge the Zone information.
The source data facilitates to make the same or similar configuration to another transceivers and saves your configuration works.
Furthermore, you can copy the Zone information from the stored source file to the data file.
BirkenVogt
BirkenVogt
That is the problem, I read the help file but I could not really understand what they were saying.
I would love to have a way to transfer large blocks of data around the various programs, you know it drives us all nuts having to type it all over and over.
I guess I need to try to figure it out some more. Does zone merge always use a source file or is it also somehow internal to the program? I don't know how to use it at all.
Sometimes it seems info is lost in translation.
Colton25
I'm very confused just like you are or were, did you ever find out how to do this? I just need to move a zone from my tk-2180 to my tk-7180.
BirkenVogt
BirkenVogt
It has been a while since I had reason to do something like this but I used zone merge like it says in the other thread. I don't remember any more than that. I don't think I ever figured out the source file thing.
