What is best way/connectors
i have 75' LMR 400 with N male on each end which will be fine on antenna end but i want to make sure i have the least amount of loss by using the proper connectors on the cable to scanner end..N male on cable to BNC antenna on a PRO 2096..what is best to do??
#2
an N to BNC adaptor would be great,. however, you mgiht also consider putting a short flexable cable with an N on one end and a BNC on the other in place of that adaptor - then your LMR400 will not drag your scanner around.
