What is Error Code 1
BigC801
Kansas City
My brand new Trx-2 comes up with this error code almost every time I try to use it I searched and didn't find anywhere to say what is wrong.
I have reformated the card a few times and redownloaded the libary, done the same with a different card to, it doesn't happen at startup just during use.
sparklehorse
Portland, Oregon
When did you last update the EZ-Scan program, CPU, DSP and Library? This sounds like the bad update they released on 12/15 and fixed on 12/17.
kruser
West St Louis County, MO
Whistler actually released fixed CPU code around 3:30 PM CST on the 16th.
Anyone that checked for and downloaded updates after that date and time should be safe.
But... if you updated the CPU code between 12 Noon CST on the 15th and about 3:30 PM CST on the 16th, you likely have the bad CPU code, version 4.0.
The CPU version should be 4.1 or later or 3.3 or earlier if you did not update anything.
If your CPU Version says 4.0, you need to update to 4.1 or roll back to 3.3 or earlier if you don't need NXDN support.
The DSP code was also updated on the 15th but it appears the radio still works fine if you roll back to CPU 3.3 or earlier.
The PC App (EZ-Scan) was also updated on the 15th and again on the 16th but that also appears to work fine if you roll the CPU version back to 3.3 or earlier.
BigC801
Kansas City
Well when this all started I still had CPU 5.00 I think
I then updated the Library files to 501 and that's when it all went bad.
It started working again when i put CPU 5.01 on it.
Some how in the process the library files also became corrupted and caused EZ scann to keep crashing and locking up, took me forever to get it working right but it is now.
Thanks for the replies.
