OK, one last question. When you switch antennas are they on the same mount in the same spot or different? The only way to properly compare antennas is by taking careful measurements and observations and they MUST be in EXACTLY the same spot or you'll get different results even with the same antenna. It's kinda funny that way, you'll immediately notice "shifting signals" in a mobile even when you move only a few feet or inches, even on the base antenna blowing in the wind.
"The Austin Ferret is especially sensitive on VHF Hi band and that band is most affected by FM broadcast overload."
That's a characteristic of the antenna alone, not common to all antennas "sensitive" on hi band. Case in point, a high gain band specific antenna is LEAST likely to be affected by out of band signals. I'm becoming more and more convinced the antenna is much like the animal, fun to play with but mischievous so never turn your back on it and has yet another notable ferret characteristic, stinks like hell when wet.
