What is NAC,PL,TRS? and what is repeaters
Bronson24
Frostproof,FL
For Motorola and Project 25 (APCO-25) systems, all trunk tracking scanners accept what is known as the Uniden Decimal format, that is the DEC number you see in the Talkgroup display. The HEX number is the actual Motorola Talk Group equivalent of that number as a hexadecimal. Professional radios (such as Motorola handhelds) and the newer GRE PSR-500 and PSR-600 scanners can use them (as can the Uniden XT series), but other scanners can't. There is a correlation between the two, but this correlation is different depending on the system being looked at. Some systems use a different format all together such as the LTR systems (system-home repeater-talk group) x-xx-xxx format or the EDACS AFS (Agency – Fleet – Sub-fleet)
So they dont work for the PSR-800??
satosi
Southern Ohio
That information was written when the PSR-500/600 had just come out, hence it says they are "newer." As long as the PSR-800 supports (digital) trunking, it will be able to pick up those systems.
