What is this?
willieg66
Tulsa
Can anyone tell me what the model # this is?
also, is it good for scanning?
CT
a417
A demonstrative pronoun.
Sorry, the pic appears to be a 22 y/o BC235XLT. Won't do digital, will do analog, some antique trunking... If you were using it for just airband or for railfoaming you'd probably get your $10.00 out of it...but not much more.
vagrant
ker-muhj-uhn
California
Uniden BC235XLT
As for scanning, it depends upon one's needs. Click the link and review the wiki. I still have an BC2500xlt scanner and use it from time to time to monitor a single frequency as it works fine for analog stuff. I believe I purchased it in 1991 or something.
tvengr
Well Known Member
Baltimore County, MD
I agree with the BC235XLT. I have one next to me as I am replying. It has a 4 cell sealed rechargeable battery pack. Good luck finding a replacement.
willieg66
Tulsa
tvengr, nice to talk to you again. What can you listen to on this beauty?
Here in Tulsa, most everything has gone digital.
vagrant
ker-muhj-uhn
California
A cursory Google search provided various links to batteries for that scanner.
Plenty of things to monitor with that scanner. I recommend reviewing the Radio Reference database for your area. Additionally, there is the air band and other stuff that is not encrypted.
rfwyzard
I have a BC245XLT and it says Trunk Tracker II so it might be an earlier model. go to www.completebatterysource.com for new batteries. I just bought new batteries for mine along with the same for my Radio Shack PRO-90 which is almost identical to the 245. Also new batteries for my BC250D. They all work fine and don't cost an arm, leg or any other body part.
tvengr
Well Known Member
Strictly analog. On the battery cover:
12 BAND COVERAGE BC235XLT
29.0-29.7 MHz 10 METER HAM
29.7-50.0 MHz LOW BAND
50.0-54.0 MHz 6 METER HAM
108-137 MHz AIRCRAFT
137-144 MHz MILITARY
144-148 MHz 2 METER HAM
148-174 MHz HIGH BAND
406-420 MHz FEDERAL GOV.
420-450 MHz 70cm HAM
450-470 MHz UHF BAND
470-512 MHz "T" BAND
806-956 MHz "800" BAND
I never checked for batteries. Good to know!
KCoax
I had Batteries Plus put in a new battery on a 245xlt. That was 15 years ago, though.
