What kind of outdoor antenna do you use for scanning?
  • Total voters
    76
thewenk
Idaho DB Admin
Eastern Idaho
Need more choices for voting. I use two antennas and a diplexer as listed below.
Dave
KJ4FWA
My own little world
My signature really says it all... my scanning Consists of a groundplane type Antenna, a 800mhz Yagi. 2M ham is covered with a J pole with ground plane elements.
737mech
Clark County, NV.
Scanning antenna
Depends what you want as discussed many times over in this forum. For me its the Radioshack Mag Mount and an AT-256. This combo gets me all the VHF/UHF and 800-900 systems I monitor. OBTW I have tried the 20-176, and the other 73 dollar discone from RS. My current combo is a "get ir dun" setup.
Pro-2051/BCT-15/PSR-500
Turbo68
East Devonport,Tasmania,Australia
I use these antennas for my radios.
Regards Lino (Melbourne Australia)
1/AKD-HAA WATSON ACTIVE HF VERTICAL 30KHZ-30MHZ
1/COMET-DS3000 DISCONE
1/DIAMOND-D150 DISCONE
1/DIAMOND-D777 VETRICAL 120MHZ-300MHZ
1/DRESSLER-ARA2000 LL ACTIVE VERTICAL 25MHZ-2.0GHZ
2/ICOM-AH7000 DISCONE
1/LF ENGINEERING-800 SKYMATCH ACTIVE VERTICAL 10KHZ-50MHZ
1/MFJ-1024 ACTIVE HF VERTICAL 50KHZ-30MHZ
1/PAR ENDZ HIGH PERFORMANCE HF 45 FOOT 10KHZ-55MHZ
1/POLAR-214A DIPOLE COMMERCIAL 118MHZ-136MHZ
1/RFI-GP3 GROUNDPLANE COMMERCIAL 118MHZ-136MHZ
1/SCANMATER WIDEBAND VERTICAL 500KHZ-1.8GHZ
JGP
Franklin, Wisconsin
Mon-3
I am using a Par Electronics MON-3 VHF/UHF/800 MHZ omnidirectional antenna on my tower. It works great, and holds up well in high winds.
Shrike
Casper, WY
DPD Mil-Tenna Omni w/Advanced Receiver Reserach pre-amp for Mil-Air
DPD MURS for VHF
PAR EF-SWL for HF
Mike
Casper, WY
N8DRC
Grass Lake
RS 20-176
Antenna Warehouse Scanner Beam
Scantenna (x2) w/ gre 3001 pre-amp
Wilson 800 yagi (x2) w/ gre 3001 pre-amp
400 mhz yagi
