What kind of yagi antenna is this
riccom
SLIDELL, LA
#4
No got this while removing and upgrading the PTC for a class one railroad
Sent from my C6730 using Tapatalk
bsmotril
Central TX
#9
Probably for Automated Train Control System (ATCS) transmissions in the 800 and 900mhz band. There is SW you can download and use with a radio with IF output monitoring those frequencies that will show you train, signal, and turnout position data.
