What needed to programmed on a radio to register to a site
jensonbut
What the field or information needed to programmed on a radio(XTS5000) to get register to a wide trunk system on a GTR8000 base station.
cheers
newbie....
fwradio
Texas DB Admin
Fort Worth, Texas
Information... you need authorization, not information. You need to get a scanner if you want to monitor a P25 trunked system.
Save yourself a lot of money and grief. Don't try to be fancy and use a radio to scan if you are not authorized to have it on the system.
(there was no butter in the popcorn, or I would have had some too.)
jensonbut
Scanner?
I have the frequency, system wide id and had my radio ID added into the system.
I realized I am still missing some information to get the radio to register into the wide trunk site.
bezking
On the Road
If you are authorized bring it to your system administrators and they will help you.
If you are not, buy a scanner.
closed.
