What practical data comes from a TAP
Chris0381
I am not new to scanners but I am new to this dicriminator tap thing. I have an old 895XLT sitting in the closet. I do have training in electrical assemby. If I spend some time to learn how to tap this thing, can I ask what useful information (in laymens terms) can I get from installing a tap? Can someone provide a screen shot of some pretty cool data that may convince me to install a tap.
I have searched the info I am requesting but it given to me in a lot of jargon I am not familiar with.
Chris0381
Thanks.
It appears as simply more specific data for whats going on with the frequency at a particular time and may be fun on occasion but Im not going to constantly use the computer and scanner at the same time. Ide like what I saw and would like to give it a try. Does anyone have any pictures of how to tap a 895 xlt (besides the location of the tap which I already have) and is it as simple as running a cloner line from the tap to the soundboard of my computer.
I am looking to see how the capacitor, resistor, and ground wires are run.
jellotor
Hamilton, ON
Check out mods.dk...there's a list of radios and scanners there that can be tapped. The 895 is one of the easier radios to tap and I believe there's a picture of the tap point on that site. Simply run a line from the tap point to an audio connector of your choice mounted on the scanner's case, then a suitable cable from that connector to your soundcard input or slicer.
morfis
A good site for general "discriminator" info is:
http://www.discriminator.nl/index-en.html
The author makes and seels quality interfaces as well.
(no, I'm not connected with him or his site in any way).
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
We actually have a wiki page devoted to the subject of data slicers - if you need one, that is - right here...
http://wiki.radioreference.com/index.php/Data_Slicers
At the bottom we've got a few US Based distributors, including DataSlicers.com. I've got one of his, and they work well.
I mentioned that you might not need a slicer. UniTrunker doesn't use one, for example. It depends on what software you will use. All software that reads a high speed data channel will need the tap - Greg Knox's pic and description are a good start for the 895.
73s Mike
Chris0381
Well I guess my main question is should I use resistor and capacitor?
If so how are they connected ?
And were is a good ground connection for the other side of the phone jack.
dbrown2
Greer, SC
Chris,
The resistor is connected to the board and the capcitor is connected to the resistor with a wire from the other side of the capcitor to the lead of the phone jack. I grounded mine to a screw on the board.
