what programming software do you use?
PA
#2
What model? "Bearcat" is a name associated with 20+ different scanner models going back to the 1970s.
Petersburg, Virginia USA
#3
interesting, there are different softwares for different model bearcats?
Now obviously the 70s models won't be using software to program them but as far as say a .........396 or 996.
Or the newer bearcats.
PA
#4
You're still being too vague. There are too many different models with different software options for a meaningful software recommendation in the absence of a specific model.
ProScan probably supports the most models, but may or may not support the one(s) you are interested in.
Again, what specific model?
#5
how many different programming softwares are out there?
There isnt one that does all of the latest Bearcat? I can't really give a model right now. If I were to buy one it would be a newer digital bearcats.
Evansville, IN
#6
OH Gee there is BUTEL, Proscan, Freescan various ARC software depending as was stated on the model scanner.
And the x36 series along with the HP series has Sentinel
PA
#8
Figure out what scanner you want, then look at software.
You're trying to buy tires before you know whether you're getting a minivan or a Mustang.
jaspence
Michigan
#9
Software
Just to clarify, Butel makes the ARC series of programming software. There are some programs written by individuals for a specific radio, mainly in the ham area.
