What scanner for Rochester?
bubbamark
Can someone please advise me on which scanner would be good for Rochester PD/Olmsted County Sherriff. I really don't know anything about the digital stuff so I'm not sure which scanner I would need to be able to monitor them. I am looking at a pro-96 as I would prefer a handheld so if someone could please tell me if this one would work I would appreciate it!
Thank you
Forgot to add that where I live I need a triple trunking analog scanner which I use now so will the digital work fine here? I live in WI now but my family is from Rochester and I grew up there so when I go back I would like to be able to monitor RPD like I use too so I would like to find one scanner that I can use in both places.
wogggieee
Hugo , MN
Uniden BCD-396XT should work well for you. I had a Pro96 before and that would work too, but i think the BCD396XT offers a little more flexibility. I think i've heard that in the Rochester they do encryption full time. Someone else can speak to that better than I can. That might also be something to consider. If it is encrypted you really wont need to spend the money on a digital scanner if your home area is analog since you wont be able to hear the digital stuff if its encrypted.
bubbamark
Thanks for the info. I will wait to see if someone can clarify on the encryption. Again thanks for the recommendation!
mmtstc
Ø
Minneapolis Area
Olmsted Co uses encryption intermittently on their LE Main 1... maybe about 2% of traffic is encrypted.. often times only when there is a large strike force action or something... there is plently to listen to in rochester that is never encrypted on digital... Fire, EMS, PW, Parks and a bunch of other misc agencies...
When i lived down there, i had my BCD 396T running and rarely was inconvenienced by encyption... I would have no apprehension about buying a digital scanner for down there...
For a new digital scanner user, i would agree with matt and recommend a Uniden scanner... they are a bit more expensive, but they are worlds more understandable as far as programming goes, and their user interface is much easier to read...
bubbamark
Great info. I will be looking into the recommending scanner. Thank you both for the great advice!!!
dugan
The north shore of Lake Erie. The Great Lake that
"but they are worlds more understandable as far as programming goes"
I agree with your advice to this member, but I think you might be overstating your point here a bit. While the learning curve may be steeper at first with the GRE product, I think ultimately it is more flexible and when you "get it" it is really quite simple. Anyway that is the way it seemed to me after a few days alone with the scanner, the manual and some programming software. Prior to owning my GRE, I had used nothing but Uniden scanners. I still have several and they are fine products. For portable digital scanning I generally grab my GRE. It just works better for me, especially while I am on the move.
Just my two cents.
fwfdengine2
Minneapolis
Go with the BC396XT.. will work great.. Don't forget it is illegal to run scanners in vehicles in Minnesota without being a peace officer or HAM operator..
fwfdengine2
