I've heard a few as well, both on 8992 and 11175. The other night was addressing SKYKING. Are EAMs live transmissions or pre-recorded ?
SKYKING is a codeword for a special order EAM. Usually for the deployment or launch orders for Nuclear weapons. The receiving stations are usually ICBM Launch Control Facilities across the U.S. and probably B-52 Standby Bombers. A little bit about GCHFS and EAMs.
Oh and those are not pre-recorded. That is a LIVE REAL-TIME human you're hearing broadcast that message, and on the other end of it are live real-time humans decoding the message and then going into a secure lockbox to authenticate the code and follow a set of launch instructions. PRAY that one day you don't hear an ACTUAL non-exercise message.
"The Global HF System (GHFS) was stated by the US Air Force in June of
1992. This system was created by consolidating several other USAF HF
networks, including the Strategic Air Command "Giant Talk" system. The
goal of the system was to develope a worldwide HF network for
providing Command & Control HF communictions to all authorized DOD
aircraft and ground stations.
When you hear an aircraft or any stations calling "MAINSAIL" on any of
the GHFS frequencies this is a "general" call for any ground station
to answer and provided the calling stations with what ever he needs.
Any GHFS ground station will respond to the call "MAINSAIL". Depending
on the service required, the station bay request the aircraft to
change to a discrete frequency for improved and extended service.
EAM's or Emergency Action Message. Another very important aspect of
the GHFS is the transmission of EAM's. EAM's are the coded military
orders or bulletins that have the highest priority. When EAM's are
broadcast, ALL other users of the system are to standby. If you hear a
voice giving a long series of letters phonically this is an EAM.
SKYKING messages are special EAM's. These presumably could be the
nuclear go/no-go codes. There was a higher than normal number of EAM's
and SKYKING messages being transmitted after the attackes of 9/11/01.
Urgent SKYKING messages are repeated three or four times instead of
the usual two. SKYKING is a group callsign, meaning "Any this net."
"Do not answer" is the standard procedure ofr self-authenticating
broadcasts, meaning that recipients don't need to give away their
positions or existence by challenging the orders. While tuned to any
of the GHFS frequncies and hear "SKYKING SKYKING Do not answer" you
can bet you're hearing a very important, highest priority, and heavily
encrypted message!"
http://www.scanaustralia.bigpondhosting.com/military/GHFS.htm
