I understand the basic concept of FDMA vs TDMA, but I was wondering what the actual advantage of TDMA is? I know cell phones have been doing something similar for years, so what's the benefit to radio users?
...This allows existing 12.5 kHz wide license holders to double call capacity by upgrading their infrastructure to Phase II.
So would systems that transition from Phase I to Phase II be able to reduce their licenses once the transition is complete, or would they keep them to handle increased traffic down the road?
V = 2(F-S) where V is voice paths, F is the total number of frequencies and S is the total number of sitesNot quite double, the control channel is still 12.5KHz, so on a 6 channel system, one whole RF channel is the control, so you end up with 10 voice paths for 6 RF channels. 8 voice paths for 5 RF channels ect. For a TDMA system it will be 2 paths less than double the RF channels.
Sent from an unknown place...
That's what I was figuring. Are the systems taken into account when they apply for frequencies? For example, if a system is going to be Phase II from the get go, would they get less channels than they might otherwise get?In theory yes, but with channels hard to come by in places, I doubt an agency would give any up "extra" channels after migration.
How is it saving you money if you already own the 6 FDMA LTR repeaters & mobiles and now the FCC tells you to throw them away and spend more money to replace them with something new?
12.5 TDMA (Mototurbo) may just be an acceptable transition system. The FCC does accept TDMA as being "6.25 efficient" on 12.5 channels but what happens when the 12.5 channels go away? When the FCC began the narrow banding process about 15 years ago they said that 6.25 channelization is their ultimate goal. 12.5 is just the transition phase. The FCC will determine in 2015 if it will be necessary to mandate 6.25 and if so how & when.
Obviously you can double your capacity on existing 12.5KHz channels with either TDMA or 2 VN-FDMA repeaters, but that is not the FCC's concern. They want to cut your spectrum in half again so they can make new 6.25 channels for new licensees. If and How any 12.5 wide radios (TDMA or whatever emission) will exist on the FCC's future 6.25 channelization plan is yet to be determined. So if you have six - 12.5 channels today the FCC may mandate you to six - 6.25 channels, rendering Mototrbo obsolete. Or perhaps they will permit the equivalent spectrum of three - 12.5 channels in the form of 6.25 adjacent pairs. meaning that TDMA systems will actually have to operate "6.25 efficient".
What is Narrowbanding?
Narrowbanding is an effort to ensure more efficient use of the VHF and UHF spectrum by requiring all VHF and UHF Public Safety and Industrial/Business land mobile radio (LMR) systems to migrate to at least 12.5 kHz efficiency technology by January 1, 2013.
More specifically, all existing Part 90 radio systems operating in the 150-174 MHz and 421-512 MHz bands have until January 1, 2013 to convert those systems either to a maximum bandwidth of 12.5 kHz or to a technology that provides at least one voice path per 12.5 kHz of bandwidth or equivalent efficiency.
What does Equivalent Efficiency mean?
Any of the following meet the 12.5 kHz equivalent efficiency requirement:
• One voice path in a 12.5 kHz channel
• Two voice paths in a 25 kHz channel
• Data operations on channels greater than 12.5 KHz must employ data rates greater than 4.8 kbps per 6.25 kHz channel, such as 19.2 kbps per 25 kHz channel
Has the FCC established a schedule for mandatory migration to 6.25 kHz efficiency?
No. The Commission has not set any date by which licensees must operate in 6.25 kHz efficiency. The current mandate only requires users to migrate to 12.5 kHz efficiency by January 1. 2013.
No - TDMA systems are not already considered 6.25 as far as the FCC is concerned. No where in the rules do the say that or use the term "equivalent to 6.25". They do use the term "efficient".
No - TDMA systems are not already considered 6.25 as far as the FCC is concerned. No where in the rules do the say that or use the term "equivalent to 6.25". They do use the term "efficient". I think the poster in #9 probably has it right. He says that he can replace his 6 - 12.5 LTR channels with the 3 - 12.5 trbo channels (or x 2-VN ) and be as efficient. And that might be what the FCC will require in the future.
I'm not trying to knock any TDMA system, I'm just saying that either the FCC is going to narrow band again to 6.25 channels, or they won't. And all TDMA systems require 12.5 channels.
Having said all that. TDMA as a technology is not all that efficient for MA (multiple access) and it does have its faults. 1:1 efficiency (compared to FDMA bandwidth) may be of some cost savings in hardware but the FCC is concerned with limited spectrum and creating new channels for future users. TDMA quickly outlived its usefulness in the Cell industry and was replaced by CDMA which is a much cleaner and more efficient technology. With all of the development in the LTE area and other wide band needs in public safety, I would almost expect that PS channels will actually go wider while other private services will go narrower by necessity.
There is when it comes to 700. Some areas including Central Maryland (for the CMARC system) have already submitted waivers.
