What's the Service Group for the Railroads.
mrlthse
LAYTON, UT
OK, What is Sentinel?
I thought that the only major rail service thru Utah was the "Union Pacific"
mrlthse
LAYTON, UT
Hey,
We are getting closer to my desired area of monitoring...
Does anyone know the FRN for the Utah rail services
mrlthse
LAYTON, UT
Well,
looking up thru the FCC record for Rairoad Freqs in the "IG" sevice group
For the state of Utah I only get eight hits.
What search parameter should I be searching?
mrlthse
LAYTON, UT
Wow...
Searching the FRN of the Callsign of KFQ404
I see there is over 239 listing...
This might take a while to find the Freqs to find Utah, State of listing...
Any suggestions?
burner50
The Third Variable
NC Iowa
I think you're trying to find specific frequencies for a specific railroad. Railroad communications are generally channelized and in a pretty narrow band.
My suggestion is to scan the entire railroad band.
mrlthse
LAYTON, UT
That would be a good Idea,
However, One thing I do know is the VHF-Hi 97 Channels that are out there for the rail service.
I am therefore just interested in the "Callsigns" of the ones that are licensed to the primary user,
Which is "Union Pacific". And are assigned to the Ogden Utah Area Primary.
Wow... What a narrow search range that is to be.
AK9R
Staff member
Super Moderator
Central Indiana
I am therefore just interested in the "Callsigns" of the ones that are licensed to the primary user...
In all my years of listening to railroad radio, I have never heard an FCC callsign being used over the air. Maybe it happens in some places, but I've never heard it.
Did you look at the RadioReference Database for railroads in Utah as suggested in post #8?
mrlthse
LAYTON, UT
In the past..
I have just went into the FCC record Data base and looked at every Frequency (Of the 97 available)
and looked for the "Filter" of Utah and proceeded that way...
And Yes, I agree I have never copied the Railroad service ever using there Callsigns over the air...
kg6nlw
Railroad & Ham Radio Extrodinare
Sonoma Co., California
We don't use callsigns over the air. The closest you get is "UP 1234 to Dispatcher 14" and vice versa.
Regards,
-Frank C.
mrlthse
LAYTON, UT
Thank you for your input,
I take it you are a rail employee,
And you are Just trying to keep
thing secure and straight.
Good Job indeed.
burner50
The Third Variable
NC Iowa
The Southwestern Wireless Con+ system that uses the System ID of 231 used to be grouped in with the 231 system in Texas until I found out directly from SwW that their system isn't assocaited with Texas system and they do not offer any type of roaming. This is why it lives on its own. The SwW system has been logged recently and the sites are accurate. I can't speak for the Texas 231 system.
Regards,
-Frank C.
That *IS* your callsign. UP1234.
mrlthse
LAYTON, UT
OK,
I do understand that part...
and that is reasonable, between railroad (crew) employee.
But, As far as for us the monitoring person goes,
The FCC assigns a callsign in which is different between from the rail service,
And that is what I am looking for, along with the FRN numbers...
Railbender
NW PA
If you want to see some callsigns (Which you will never hear over the air.) go to the Radio Reference data base, State Utah, Railroads. Notice UP has very few call signs listed. For monitoring purposes they are of no use anyway.
sonm10
Central MN Monitor
Sauk Centre, Minnesota
OK,
Dude, I gave you the answer a few posts ago. Post 11.
