scottyhetzel
Clarification
Hi inigo,
This will help bring clarity...
1. The traffic that is important can be repeated clearly by the dispatcher in a calm fashion. Especially when the duputy is in foot pursuit. Its aamazing how there can be major havoc and the scc dispatcher will be calm responding on the radio, which actually calms the deputies as they are responding. Calm deputies equal great decisions during driving and at the crime location....
2. Crime broadcast by the deputy are usually " patched" by request of the deputy. For example " temple 52 adam and all monitoring agencies a GTA ( grand theft auto) just occured in the 1000 block of las tunas, possibly heading west bound by one occupant, no further description....52 adam clear you can drop the patch". Of course patched communication happen on hot calls too.
3. Officer/deputies get indidated with info. Overload, so hearing beeeps can give a little tranquility. When there is voice, you know itts important. Listening to people talk with lazyness and with background noice getsbvery annoying on a 8/10/12 hour shift. Kinda like listening to a dj on the same fm radio station all day.
Hope This helps...
LASD decided a very long time ago that it would confuse their deputies too much if they could hear each other. Therefore on the dispatch channel, all the deputy ever hears is their dispatcher and the "beep beep" busy tone when another unit is talking on the input frequency. They have had repeater capability for a long time (called "the patch") and occasionally turn it on during hot calls to allow deputies to relay BOL info to other units in the field directly. They then quickly turn it back off. Since there is a legitimate need for the sergeants to direct units in the field, you will hear cHar-to-car traffic on the corresponding L-TAC frequencies for each area.
The busy tones also allow their dispatch center to dynamically rotate radio usage between different dispatchers based on call volume. In other words, you may hear one dispatcher on the channel one minute, and then the channel will get automatically moved to another dispatcher with a lower workload and you will hear a new voice. In a way it's almost like trunking on the dispatcher end... It allows them to have fewer dispatchers work a larger area, but virtually every other department I'm familiar with follows the traditional solution of simply hiring more dispatchers. In my humble opinion, it seems like an overly complicated solution to a simple problem.
The busy tones are one of those strange cultural department traditions I will never understand. I've heard plenty of other reasons for why they exist from those in the department (many even posted in this forum and you can do a search and find them), but it just never makes logical sense to me... So I've given up trying.
Hi inigo,
Hope This helps...
