Where did the Pal Interstate Parkway PD Go?
WILSON43
Northern New Jersey
Brought up their VHF freq as listed in the database for last night's storm, and crickets?
What gives? If they moved, is anyone going to update the database?
w2xq
Burlington County, NJ
Wirelessly posted (Moto Droid Bionic: Mozilla/5.0 (Linux; U; Android 4.1.2; en-us; DROID BIONIC Build/9.8.2O-72_VZW-22) AppleWebKit/534.30 (KHTML, like Gecko) Version/4.0 Mobile Safari/534.30)
Dconti, I believe the RR SOP is to retain entries so long as the FCC license is not expired or cancelled. HTH.
w2xq
You can limit the scan to the particular talk groups IDs the Pal police dept uses.
PJH
Global Database Admin
Depending on the cut over, the freq may be listed as "depreciated" or outright deleted. In the handbook, the deprecated freq's should not remain in the database for a long period of time. The uniden software will see that tag and not scan a depreciated channel.
WILSON43
Northern New Jersey
"You can limit the scan to the particular talk groups IDs the Pal police dept uses."
OK, can anyone tell me the talk groups IDs?
davewhall29
Knoxville, TN area
New Jersey Interoperability Communications System (NJICS) Trunking System, Statewide, New Jersey - Scanner Frequencies
is the link to the NJICS. Scroll down until you see Palisades Interstate Parkway Talkgroups about halfway down the screen. The DB is showing that they are using P25 Phase II talkgroups which can only be monitored with a GRE PSR 800 or either one of the new Unidens that are expected out any day now. And it shows they are using encryption sometimes on these TGID.
btshep
North Jersey
What kind of scanner are you running ? The PIP talk groups are Phase II which can only be monitored on the GRE PSR-800 or the new Uniden BCD-436HP & BCD-536HP scanners which just started shipping this week.
The info for the NJICS system can be found here: New Jersey Interoperability Communications System (NJICS) Trunking System, Statewide, New Jersey - Scanner Frequencies
Note: Encryption sometimes heard on these talkgroups
DEC HEX Mode Alpha Tag Description Tag
4201 1069 T PIP PD P-1 Palisades Interstate Parkway Police (Patrol 1) Law Dispatch
4203 106b T PIP PD P-2 Palisades Interstate Parkway Police (Patrol 2) Law Talk
WILSON43
Northern New Jersey
Thanks for the information. Currently running HP1 scanners in the base and mobile.
Not quite ready to drop another 5 or 6 hundred bucks on another scanner to listen to the PIP PD, and certainly not until user reviews are forthcoming and the prices drop, which they will.
Thanks again.
jvdet
north jersey
IF it matters the VHF freq is still used to communicate with local EMS/Parmedics when responding to incidents in the park
RadioDitch
Nomadic
FWIW. As crazy as it sounds, the use of encryption isn't a matter of policy but rather is arbitrary depending on who's dispatching. Most enable the encryption, others are fellow radio geeks and turn it off at the dispatch console (and they can on their setup).
So it's a matter of listening on the right night.
