Where is MEDIVAC in the South Jersey area
nr2d
Laurel Springs, NJ
Since around Jan 1 of this year I haven't heard the MEDIVAC helos being dispatched in the South Jersey/Philadelphia area. I had 155.220 MHz programed for the dispatch/traffic channel for MEDIVAC but I haven't heard them since then. I still hear PENNSTAR and REMS on the NJSP network.
W2SJW
Senior Member
Moderator
Northwest NJ
SouthSTAR & the birds from PA & MONOC are still the primary coverage ships. The majority of action is still on the NJSP system (as you noted).
robnj74
Buena, NJ
I hear SouthStar, Monoc ,and a couple others on the NJSP network primarily..Can also try 463.17500 NFM DCS 156, or 462.96250 NFM CTCSS 210.7
Rob
K2RJJ
wildbillx
Cape May, NJ
Medevac 5 and Atlantic Air 2 are the 2 South Jersey helos. Medevac 5 is out of Millville airport and Atlantic Air 2 is out of Woodbine Airport.
W2SJW
Senior Member
Moderator
Northwest NJ
Isn't that the company channel for Air-1 (non-emergency transports)?
Sent from my Galaxy S4 via Tapatalk 4
robnj74
Buena, NJ
Sentinel would lead one to believe it's EMS Dispatch (as they label it anyway).
Rob
K2RJJ
kennyloatman
Cumberland Co., NJ
Just heard medevac 5 land at Inspria hospital in Vineland advising REMS of such. First that I have heard them in a while, Maybe since the first of the year.
Devilz311
NJ
Medevac 5 is based out of Inspira Vineland, Medevac 4 is based at Woodbine Airport, and Atlantic Air 2 is based at Millville airport. If you hear Medevac 5 or 4 landing at Millville it's for refueling.
Medevac 5 is actually pretty busy, they've done a lot of flights since then.
