Where is Universal Trunker RID information stored?
W4KRR
Coconut Creek, FL
I am running Universal Trunker. I am adding and labeling group ID's as well as RIDS. When I run the program, all the info is there. But, when I go to "C:\Program Files\rfmobile\uniTrunker", the file that should contain the RIDS (in this case "Moto1f25.RID") is NOT the current copy, it is old, last updated five years ago. Where is the most current data stored?
WyoWabbit
Casper, WY
In a file named "Unitrunker", in the Unitrunker folder. It is an XML document. All talkgroups and radio id's are here. - Tom (P.S. this is for version 23 anyway).
Go to an open receiver or site window. Click on the folder icon. Windows Explorer will appear. Navigate up one folder. Look for the Unitrunker.xml file.
W4KRR
Coconut Creek, FL
Thanks guys, I got it!
Now, what is the best (easiest) way to get that data into Excel? Import from within Excel, or export into Excel?
You can export a single system to a separate XML file. Import / Export via a format understood by Excel is a feature on the things-to-do list.
Jay911
Bragg Creek, Alberta
There's no real easy way IMO. I hand-edit a copy of the XML in a text editor like Notepad++ so that the data is arranged in columns, with tabs in between the data, and then either cut-and-paste into Excel (or OpenOffice Calc, its equivalent) or save the edited file as a CSV file and load it (both do essentially the same thing).
W4KRR
Coconut Creek, FL
Thanks for the tip, Jay.
Also, to "Unitrunker"; per my original post, I had been looking in an old, inactive folder containing an older version of the program, which explains why the data was old.
Apparently, older versions of Unitrunker were installed in a folder called "rfmobile", whereas newer versions apparently don't include that folder.
