Where to find a BC300 Service Manual?
pro92b
Mutated Member
I don't believe there was ever a service manual released for the BC300. In the attached letter from 1981 I requested a service manual from Electra and they said it was not available. The schematic they did send is the one that you can now find on the web. At the end of 1983 I tried again to get a service manual but only the schematic was available from Electra. Not long after that Uniden bought Electra's scanner business.
  • BC300 Service Manual.pdf
ipfd320
Banned
W.Babylon N.Y. 11704
I Found Scematics also here----http://w5jgv.com/downloads/Bearcat/Bearcat%20BC300%20Schematic.pdf
A Couple of Tech Tips Here----http://w5jgv.com/downloads/Bearcat/Bearcat%20BC300%20Repair%20Tips.txt
As for anything Else..I Searched a Bit and Found Nothing Worth Wild---You Did Not Mention Why You Need the Manual---That Could Help a Bit
Astrogoth13
City of Angels, CA.
Thanks for the help everyone. I got this 300 in great condition but I am sure it needs a mass cap' replacement and, if possible, an alignment. Hence the service manual..
Oh well, I will adapt.
Astrogoth13
City of Angels, CA.
"For part alignment see XD529-02."
Sure! Where is that located?? And while I'm moaning where on the board is C98 located? Roughly.
Astrogoth13
City of Angels, CA.
Okay, for future reference I found C98. With the case apart and the buttons facing you, to the left of midline you will notice a medium sized transformer. Immediately above the transformer are two medium sized electrolytic cap's. The one on the left is C98, clearly marked. But. My C98 is a clearly marked 100uF 35V! The solder appears to be untouched and as old as the others near it. I will still put a 45uF 35Volt cap in its place. My display is very dim.
jonwienke
More Info Coming Soon!
VA
Bad idea. Unless you are ABSOLUTELY sure the original part was wrong, the uF ratings of the original and replacement parts should match exactly, and the replacement part's voltage rating should be equal to or greater than that of the original.
jonwienke
VA
I would trust the markings on the factory original part over a schematic.
Astrogoth13
City of Angels, CA.
Okay, replaced 4 cap's. The display is still too dim, but the radio works. So I went looking and found an unsoldered part. Fixed it. Wiggled the ribbon cable where it plugs in, very carefully. Tightened all the inner case screws for a better ground. Straightened a few parts. Reassembled the case and everything but the display works better. The Ham button and the Hold button now work. The banks all work. But there is now a 60 cycle hum to wake the dead. And the display is still too dim. Tomorrow.
Ubbe
Stockholm, Sweden
If you replaced a 100uF filter cap with a 45uF I would assume that would be the result.
Filter caps should always be replaced with the same or bigger values in both uF and voltage.
/Ubbe
Astrogoth13
City of Angels, CA.
I did it in stages. First that cap. Then I tested it. Nope. No hum. No change at all in fact. And larger filter caps are okay. Better in fact.
Astrogoth13
City of Angels, CA.
So which is it???
Whatever dude.
It's a new day. Today I looked and found two more bad solder joints. Tested the repairs.... No improvement. Loud hum still mostly covering voices on the radio. It needs a complete capacitor replacement job and frankly this scanner, as nice as it looks, isn't worth all that work. As I went along fixing things I was also making other old parts fail. Frustrating. So, this BC-300 will sit on a shelf and remind me of my teen years. Hope all this helps future BC-300 owners.
I still wonder how this thing ever made it out of the factory. It couldn't have worked well with so many open circuits. Time didn't do THAT.
VK3RX
Thaumaturge
Australia
Try operating it on DC. The problem is most likely in the PSU and all those caps should be replaced, but its worth trying.
Agree re the build quality. Not quite as bad as some Grief-kits I've seen, but -
