Which Satellite work in 135-140MHz??
May be : LEO satellites
what is their names? and their task?
Here are a few great links for 136-138 mhz sats. Lots of interesting things up there too hear..
136 to 138 MHz band satellites
Satellite Radio Frequencies - 136-138 MHz band
Space Frequency Listing, 136-153 MHz, Downlink
Check out some of the links on these pages and other VHF/UHF frequencies.
73 Rover
Define "modified scanner"....
73 Rover
When I first started with APT, I was using a handheld Radio Shack
scanner. I modified it by removing the IF filter and putting in a .01
uF disk capacitor to give it a wider bandwith. The satellites have a
wide bandwith, and if you don't have the mod, it will still work, but
you'll see the whitest parts of the clouds will appear as a fuzzy,
noisy spot. I think the signal gets clipped there without the mod.
I started with a Diploe/turnstyle antenna which did work, but those
have a bunch of nulls which even if the satellite is directly
overhead, you'll get some weak spots in the signal causing dark bands
across the image. I made a QFH from PVC pipe and coax. It's been on
my roof for years working great!
Anyone interested might want to look at the funcubedongle, its a SDR receiver with a usuable bandwidth of about 80KHz, I haven't tried receiving anything from NOAA sats with it yet but I will try sooner or later. I just hope my software will allow me to adjust the filter that wide
