I recently received and programmed a whistler 1065. I used a programming software for it and programmed it using the frequencies and 3 digit talkgroup ids found on radioreference database. It programmed successful and receives great. My question is, how do I go through the scanner settings and view what those 3 digit ids are? Example, if I would come across another 1065 scanner and want to see what the talkgroup ids are that is has programmed, how would I do that using the scanner? Thanks!
