Whistler 1065
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
#2
You need 2 things - a USB cable, the link for which is here (see the Whistler section of...)
Connecting scanners via USB - The RadioReference Wiki
(links are always blue, BTW)...and software. There are 3 packages (nothing free, I'm afraid, although they all have trial periods) that are commonly used - Win500, PSREdit500 and ARC500. Links for each are here...
Object Oriented Scanner Software - The RadioReference Wiki
And at the bottom of the article below, you'll find links to user guides for ARC500 and Win500
Getting Started with your GRE/RS Object Oriented Scanner - The RadioReference Wiki
Keep that last link handy - it has links that you will find useful...Mike
