Whistler 1095 ?
#1
I have Whistler 1095 with no sd card, If I put a blank sd card in it, will there be any basic ,memory or start up in the 1095 ?
#2
You need to get an sd card,go to whistler.com and go to support and downloads,then get ezscan.Format the card using EZSCAN,add the database and the scanner should work once you have correctly setup the sd card
