whistler ws1040 try this for better sound more volume thru jack don.t push all way in just before it clicks in run a wire from speaker jack to bnc makes the volume very louder. try at own risk works great on mine
Well iam using a jump wire on my ws1040 works great using it with a Motorola speaker mic its nice lots of volume.
What amplification should I get? I got a Uniden Bearcat 15-watt Amplified Speaker. It has an 8 watt amplifier.I have used a jumper wire on my PSR500 for 10 years with no issues. However, when GRE release their PSR800 a jumper wire no longer works and you need to use a amplified speaker with the head phone jack. Make sure the OHMS of the amplified speaker are within specs of the headphone jack or you will not get any amplification.
Ok thanks. Do you have a recommendation? I'm looking for a good one for my car that I can hear well.
Yeah I have the filter turned on. The manual for my product says 8 ohm without the noise filter. I am currently waiting for some mounting materials before i listen again I will turn off the filter and see what that does. Thanks.The radio earphone jack is 8 ohm. If you are not getting more volume then you need out of a amplified speaker then most likely you have a mis match.
